Skulljeep683
hey everyone im new to this forum(first post what what) and basically just read this entire thread fishing for information (which there is no shortage of here, good info too) on doing the 4.0TB swap and adding a TBS. ive noticed that quicksand has a pretty extensive tb experimentation past so i guess ill direct this question at you (but anyone else feel free to chime in): if i add the TB/TBS, will i need to bore out my intake mani or is this all just a bolt-on operation?
Well the 4.0 has a little notch on it that i simply removed (with some pliers then sanded smooth) which prevents you from using it on the 2.5, it doesnt affect it in any way. You dont have to bore out the intake but its recommended for ideal airflow. I have to get rid of the helix in my spacer and im going to be boring out my manifold and spacer a bit and doing the same to the underside of my tb. making it all one flush and smooth air travel. thats the goal, smooth airflow transitioning, my narrow point for air charge will be the tb itself, so it willl maintain velocity through the intake. Just be sure to reset the cpu when your done so the motor can relearn how to run with more air, or you'll burn the valves up on cylinders 2 & 3 and lose compression... also after that mod best to run a high flow exhaust so you can get more power at lower rpms and watch your mpg go up. when i first commented on this thread i took notes down on everything that was said, my notepad doc on this thread is a novel. lol well hope that helps, happy wheeling.
