RudeDog
Questions
Hard top: There's (3) torque screws on each side that go through the top & into the body side rails. Each threads into a small piece of metal that's fitted up inside the side rails. On the back & middle ones I have a sliding clip that holds the threaded metal insert in place. But, on the front 2 (behind the front bucket seats) they just had no clip and so just dropped out ? Is that normal? or am I missing something (clips?) to keep them in place?
Engine Bay Light: Mines out. Is it supposed to come on when the hood opens? And how do you open it to change the bulb? Nothing in the manual.
3rd item: There's a flat OEM sheet metal (shelf?) just below the brake master cylinder. Looks almost like a battery shelf, but not quite big enough. Any idea what it's for?
