Allen's Offroad
07'-17' JK Big Bore XD Steering Gear Box
SKU #: SG685
Available for PRE-ORDER ONLY. Shipping end of February 2017. Checkout my coupon codes for potential savings before you purchase anything from Allen's Offroad. Click on image above to pre-order.
The new JK XD steering gear replaces the 70mm stock piston with a larger 80mm piston, giving it more turning torque to turn up to 37” tall tires without the need of cylinder assist. More material was added to the case in all mounting for sturdier base. Sector shaft diameter is increased from 35mm to 42mm for a 35 percent increase in strength. The JK-XD kit comes with a new factory drop pitman arm, nut and washer to match the newer larger sector shaft. Anyone with a Jeep JK running bigger than factory tires will want this bolt on upgrade on their must have list.
Options:
Pressure Hose Kit*
No Hose Kit
-8 AN Pressure Hose Kit +$100.00
Return Hose Kit*
No Return Hose Kit
-8 AN Return Hose Kit for use with DER13253 Heat Sink Cooler +$75.00
-8 AN Return Hose Kit w/ Heat Sink Cooler +$130.00
			SKU #: SG685
Options:
Pressure Hose Kit*
No Hose Kit
Return Hose Kit*
No Return Hose Kit
