Yes, I will try to post pic of it. It is raining pretty steady today and the jeep is outside right now (car broke down taking up the garage), its usually in the garage. Yes I made a plate for the floor. I used a hole saw to drill a hole for the column to fit through and bolted it to the floor, and made a L shaped tab and bolted it to the plate and welded it to the column for support. Under the dash I used wrangler tailgate hinges and hung and bolted them to the dash vertically(I did have to cut about an inch or so off the hinges for lenght reasons). It bolted right up to the column bolt holes. Im not thrilled with the wrangler hinges (you cant see them but I know they are there) but it worked out great for what I needed it to do. I can sit in my seat and pull and push on the steering wheel and there is no movement. Oh, the new column will have the ignition in the column, I filled the hole with JB-weld, sand and painted it. Same with the turn signal hole, Overal Im happy with it. Like I said, I will try to post up some pics asap. If you are wanting a restored show quitlity look, you probably want to mount it a little nicer than I did.
