1ATony
CHECK HERE FOR GREAT PRICES 1991-1999 Jeep Cherokee Stainless Steel Exhaust Manifold with Gasket 4.0
FREE SHIPPING ON ALL AUTO PARTS!!!!
Specifications:
2 bolt exhaust flange
Includes Gaskets and Hardware
Direct replacement
Replaces original manifolds that are cracked from thermal expansion and contraction
Stainless Steel
Fits the following Jeep Chrysler engines:
L6 4.0L
Gasket install kit included
Limited Lifetime Warranty*
Why choose 1A Auto?
We've installed an example of this manifold and we know it fits correctly.
0 returns in the past year for fit or initial quality.
This manifold is covered by a lifetime warranty
More reasons 1A Auto saves time and money. (Opens separate window)
COMPARE & CONTRAST OUR HIGH QUALITY MANIFOLD vs "THEIR" LOWER QUALITY MANIFOLD:
"Their" Lower Quality Manifold
Lower quality manifold has lower temperature welds as noted by lighter brass looking colors.
Lower quality manifold has thinner surface welds.
Lower quality manifold uses different material for welding than tubing which is noticeable by the shiny surface at the joints.
Lower quality manifold has flange surfaces that are sometimes uneven that would require high torque levels to bring them into plane.
Our High Quality Exhaust Manifold
High quality manifold has high temperature welds to promote better metal integration at jointed areas. This is shown by high temperature color patterns near welds.
High quality exhaust manifold has wide surface weld patterns used in joint areas for superb strength and shock resistance.
High quality manifold uses same material for welds throughout construction to allow for the same cooling and expansion rates to promote durability and reduce failure. This can be seen by the same dull color of weld bead vs tubing material.
Higher quality manifold has precision ground flanges to give best possible mating surfaces to bolt against cylinder head
Higher quality manifold has more precise radius bends allowing for better alignment between exhaust pipe and cylinder head flange
*Backed by manufacturer's Limited LIFETIME warranty. In the event this manifold should fail due to manufacturing defects during intended use, we will REPLACE the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
Specifications:
Direct replacement
Stainless Steel
L6 4.0L
Why choose 1A Auto?
