2-1/4" spacer lift TJ
Sweetnessman06
I have a 2002 tj and recently bought a 2.25" spacer lift w/shocks. Its a dd and will only occasionally be used offroad, I just wanted to check with yall if I needed to get anything else And any reviews of the lift, its a bb lift w/ skyjacker hydro 7000, and includes the extended bump stop.i plan to add a 1" bl after I get this on
Get the adjustable cam bolts for the axle end of the front lower control arms. Once installed, adjust them so it pushes the bottom of the front axle as far forward as possible. This has always corrected the caster and pinion angle for me when installing a BB on a TJ.
Il probably give that a shot. My first time doing a lift so I'm pretty clueless about it. Thanks for the help
Yeah I just did mine bout 3 months ago it's easy bout an hour on springs and 30 min on body u do need cam bolts like b hunter said I still need to do do mine also
Ok how much do those run. I saw some kits for them around 30-40, and some over 100, just not too sure exactly what I need
I found some for 40 online bout two weeks I just have a lot going on can't find time anymore I think I google (cam bolts for 03 tj)
Sorry for the last post I just got a text my g- friend is pregnant!! I guess and that made me lose my train of thought
Got it on this morning! Looks good and it wasnt as hard as I thought it would be, only ran into problems with getting the front spring back on, and getting the old shocks off, the back top was difficult bc the gas tank in the way, and the front I couldnt get the nut off the top, so I took a grinder to the bolt and came off nice lol.oh and these hydro shocks are bouncy as hell! Every bump makes it start bouncing up amd down lol
