bigschrec New member Jan 28, 2015 #1 My 4wd light doesn't come on in my 97 TJ. The 4wd works but I would like the light to also work. Any ideas on how to fix it?? Thank you
Bounty__Hunter Super Moderator Jan 28, 2015 #3 Crawl underneath and look for wires to the transfer case. The wires by the tailshaft are the speed sensor. The wires by the shift linkage are to the 4wd light switch. Switch might be bad or broken wire.
bigschrec New member Jan 28, 2015 #4 Okay thank you I'll check. I know it's not the bulb because I replaced it a year or so ago.
R Roger Carpenter New member Jan 29, 2015 #5 on my 88 the 're is a vacuum switch on the firewall near the battery vacuum comes from the front axial vac motor when in 4wd .
Bounty__Hunter Super Moderator Jan 29, 2015 #6 Roger Carpenter said: on my 88 the 're is a vacuum switch on the firewall near the battery vacuum comes from the front axial vac motor when in 4wd . Click to expand... A TJ is a LOT different.
