4wd problems
monsterrd
Hi everybody, I'm having a problem with my 4wd. The 2 vacuum lines came off, I replaced the lines but still no 4wd. Do the vacuum lines need to be primed or something?I had 4wd before the lines came off. Any tech. help would be greatly appreciated. Thank You . :-? :-? :-?
edited by: monsterrd, Mar 01, 2003 - 03:04 PM[addsig]
1057554
are they hooked up in the same positions as before... if your lines are too weak, the vacuum could be caving the lines in as well.. it takes a good amount of vacuum to make the diaphram move... if the line walls are too weak, they could be caving in on themselves[addsig]
1057557
Thanks Snitty, got it to work now,I guess it just took a little while to kick in. just went out and tried to get stuck in the snow, but blasted out just fine. Very cool club, everyone is very helpfull, Thanks. 8-) 8-) 8-) 8-) 8-) The only problem I have now is that my 4wd light is burnt out, an easy fix.
edited by: monsterrd, Mar 01, 2003 - 06:32 PM[addsig]
