1053025
I think that my horn has shorted out and is draining my battery when i turn the ignition on. The horn "clicks" when i press it, and the battery is now dead. I was wondering if anyone had some info on this. I have a column ignition, not orginal. also was wondering if someone could fax/e-mail electrical schematics for a '79 CJ. I probably should go ahead and replace all my wiring.
Also had a question about turn signal timing. Is there an easy way to increase the speed of my turn signals? as it is they are pretty damn slow! If you can't tell i'm a relatively new CJ owner, lovin it so far! thanks for any help![addsig]
