Yes, the 4cyl trans is too weak for any v8 power. you can use the t176 4spd, t150 3spd, t18 4spd and maybe a couple others that I cant think of right now. the problem you will run into with going with any trany other than the t150 and t18 behind a AMC v8 is that your jeep has a dana 20 I believe, and the other tranies mentioned have the dana300 behind it and they do not share the same bolt pattern. So any other trans than the 150 or t18 will need a adapter for the tcase. depending on the length of the new transmission you may need longer or shorter driveshafts. The 151 bellhousing is a keeper, I believe it is a buick housing and will work in chevy swaps.
