galaxyk5blazer
Finally got my jeep running. I've converted to Howell Fuel Injection and a GM HEI distributor. I noticed a misfire at acceleration and normal driving speed. I have replaced all the distributor components. Timing set at 6 degs. BTDC. With the vacuum advance disconnected, using a timing light, I noticed that the firing mark moves to zero degs. as I increase rpms, then as I continue to increase rpms the timing advances normal. Also during this I noticed that the spark is not consistent. Runs ok then I have a misfire and there's no spark for that brief second. Then it repeats. Any help would really be appreciated.
Thanks, Mike
Thanks, Mike
