86 CJ7 ( Christine) over heating
I replaced the water pump ( fun) now the water will not cycle. Naturally I think - thermostat.
It was fine b 4. I herd issues could rise because of trapped air. Is that common?
Ty- ABS
Welcome to jeepz.com. Whether it be the I6 258 or the V8 304 the same condition may exist . Yes , trapped may very well be causing this issue and likely to be the cause since there wasn't an issue before the water pump swap. With the engine off and cool and radiator cap removed , vigorously squeeze the upper radiator hose repeatedly until no air bubbles are withnessed escaping the filler neck port of the radiator . You'll want to keep the radiator topped off as you are performing this task of squeezing ( the overflow bottle as well) so that gravity will assist . The act of squeezing helps to distribute fluid mixture into the engine and through the heater core and back to radiator to help expel air pockets . Keep the level up and monitor frequently so that gravity continues to assist as you continue to squeeze the upper hose. Elevating the front of the jeep may be helpful for a V8 but seems to be essential for an I6 . Squeezing a lower hose helps as well but you'll want to start with the top simply because the manual transfer process is actually easier from the top at the beginning of this procedure than to start with the bottom . Once the level plains out and level change is no longer noticed ( and your forearm is numb) it is assumed no more air is present . You may try the lower hose to see if any effect is noted and effective . Be certain to maintain the proper filler neck level throughout the process and upon completion and overflow bottle as well. With radiator and overflow capped , now start the engine . You'll want the radiator capped because you want the cooling system to pull coolant from the overflow / reserve so that future air pockets are avoided . It will take several warming / cooling cycles at least to any small amounts of air that cannot easily be removed which usually is introduced from the radiator tank when the cap is open. The act of the overflow / reserve tank coolant flowing to radiator should fill and contain any air pockets and air should circulate back to the overflow tank , theoretically , if there are no system leaks . All hoses must be clamped tight ( but not over tightened ) and radiator cap holding correct pressure for cooling system to function properly. Make certain overflow tube as well as all hoses ( upper , lower and heater core lines in and out ) don't kink and cause restriction for system to function properly. If all previous conditions conditions are met , cooling system should maintain proper circulation and air will work its way from system soonest that cannot be expelled by squeezing hoses . Let engine run and observe temperature gauge throughout process . I should ask first that the correct water pump is in place . Does your system require a reverse flow water pump ? This is important and an incorrect pump installed will cause overheating conditions . Do not wish to doubt anyone's ability but only wish to advise for future readers not to commit any blunders as it is enough work to swap parts and no one wants to do it twice. Hope this helps and your cooling systems woes vanish. Best of luck . Thank you for your post and especially your membership here at jeepz.com .
As if my previous post weren't long enough , would like to add the following comment(s) : yes , be certain thermostat is functioning correctly and gasket not leaking . Repair/replace as necessary . Make certain all hoses ( radiator and heater , bypass , etc. ) are in good condition and installed correctly . Hoses cut too long or short present obvious problems. Too long will cause kinks due to bends where curves and turns exist . Too short will cause pulling at fastened ends when engine moves at normal angles during acceleration/deceleration . All hoses should be installed to observe proper clearance from moving belts and any possible rubbing on any surfaces . You want proper clearance from any exhaust manifolds/headers as well to avoid failure. Never overlook items such as heater control valves for proper function and condition as well. A leaking hose or valve will cause system pressure drop and system inefficiencies . Not to mention , leaks will wreak havoc on starters and alternators for example in addition to oil leaks too. Although care care month is October , car care is year round and must be observed if we are to depend on our vehicles at all times. If I missed any pointers , anyone is free to post their thoughts / additions.
Agree
Verify correct direction pump, Burp the system. Only added step is to park on a hill or jack up the front of the engine...and do the squeezing with engine running coming up to temp. This way air is getting past the thermostat.
Thank you. I learned a lot from your reply. I'll give it a try first thing in the morning.
Your friend,
ABS
Your most welcome . Wishing you best of luck . Your jeep was fine prior to the water pump swap so we're sure all will be well soon . Your welcome to post questions and results as your able . Thank you again. Greg .
P.S. - in brief , JPNinPA summarized the best plan for a quick diagnose and repair.
I found my problem. I hate to admit it but it might help another. I put the thermostat in backwards and I used to much gasket glue around the pump. The glue clogged up the pump when I tightened up the bolts.
Very sorry to hear . Don't beat up on yourself , I don't know many people who haven't erred an automotive repair and had to make it right afterwards . If I think hard , I know I've committed similar mistakes in the past. Every now and then I am guilty of something that either I Did incorrect or may even misdiagnosed . Knowing your going to have to pull the pump back off , you can use the water pump jacket as a place to run the garden hose when the thermostat is out and do a righteous flush to clean any remnants of the permatex adhesive out. You'll also want to flush and especially back flush the heater core to be certain it's clear. And yes , the radiator as well. The water pump should fare well . Again , sorry for the trouble . Thank you for your kind thoughts for wanting to help out from your own experience. Thank you for your good will and spirit.
Well use the experience to help others. In any event, glad to hear you got it fixed. Just hope the excess gasket glue didn't clog the radiator or comes back to cause other issues.
