loosecannon
So, I'm working on an older yj..when it came to me, I could start it in any position on the selector p-r-n-d-1-2. Figured...no brainer, so I screwed a be nss in the hole, and viola! Trouble is, when in reverse I have no back up lights...if I unscrew the nss out of the transmission, and plug it in to the harness and then compress the switch by hand...I get the reverse lamps. Are the detents inside the transmission not lining up properly? Is there an adjustment that I could make if I drop the pan..any tips would help..thanks!
