'88 grand wagoneer distributor
jaber
my question is will a distributor out of a '77 360cc work in the '88 360 to eliminate the dist. brain box? or do i have to replace the module? :-? :-x [addsig]
1058911
I don´t know what the smog test requirements are where your at. First question is why do you want to disable the control module. Are you having problems?
I don´t know for sure, but having messed with similiar setups, a vacumn advance type distributor and a Dodge ignition module, used as a bypass for the stock system, is possible with similiar models, easy and inexpensive. I´m guessing you have a carburated motor?[addsig]
1059050
no smog needed here, sometimes it runs just fine, the next time you try it could be dead. no power to the coil. a couple of days later it works again, and there's no patern to it. yes its carbed. :-?
edited by: jaber, Mar 10, 2003 - 07:57 AM[addsig]
