2000roo
I have an 88 YJ. I noticed that it had the wrong carb and put the correct computer controlled one back on. It is a new rebuild. The first carb was off a 74. I replaced the carb because the bowl gasket was leaking badly. Now it will not idle at all. It acts like the timing is off. What does the ecm on the 88 controll? Is there a timing advance in the ecm that is controlled by the throttle ? It will run if you keep feathering the throttle.
