I sure would appreciate anyone's help on figuring out a challenge with an 89 Cherokee, 4.0 L, in line 6 cyl. It sat all winter, started up OK, then would not restart. Fuel is getting into the crankcase. I have unhooked the injector sensor (elect. unit on top of each injector) removed plugs and turned over engine with key on. No fuel coming into the cylinders. I am figuring this might mean that the injectors are not being held open with either dirt or other debri. When I put the injector sensors back on, turn motor over, the cylinders again flood with fuel.
Have you ever seen a similar problem? Could this be the computer?
Your site was highly recommended by a gentleman who is a member.
Thank you,
Triston
Thank you,
Triston
