Bryce Heinz
Bought this not running. Replaced chassis ground and it fired up. All it does is want to idle. Randomly I can drive it for about 20 minutes but most of the time you give it has it sputters and dies. I have replaced the fuel pump and icm with no change. I have tested the air temp. Coolant temp and map sensor and all seem to be working. I was going to adjust tps but bolts stripped out. Ordered a new sensor from napa hoping it comes with new bolts. The tps was out of spec and may be the issue. Anything else I can check?
