18000
I have a 91 YJ 4Cyl 5 speed. My clutch pedal recently started to let out and catch about 2 inches from the floor. This doesnt seem to be a worn clutch problem because the pedal would come almost all the way up before catching if it were. So anyway, I followed the clutch line down from the master cylinder for the clutch and discovered that the actual line going into the trans is loose. You can pull it in and out about 3 inches. The metal line doesnt allow it to come all the way out. Does anyone know a fix for this problem. It seems as though it should be pretty simple.
