92 Cherokee header panel & grille replace
hankdz
I wrecked the header panel and grille on my 92 Cherokee. I have the new parts on hand. How do I remove old without damaging anything else and replace with new? I have tried Chilton's with no luck. Haynes doesn't do body parts. Factory service manual is no longer offered for 92. Haven't been able to locate a used one for a reasonable price. Anyone out there that can help?
get some tools out and start removing bolts and nuts until your damaged pieces are free. replace with the old. spray bolts with WD-40 if they're tight.
maybe a pic or a better description would help out if you really need help? your question is kinda vague.
FSM's can be found, but posting them or a link to them is a copyright infringement, so it may be tough to find. I'd bet if you look hard enough one will present itself.
Pop the hood and start by removing the upper radiator support. Everything else is pretty much self-explanatory and can be removed without damaging anything.
