Im not real familiar with the wranglers, but I would try and follow the wires from your ignition switch to the coil. If there is anything between the two, thats got to be it. Others with knowledge of sensors and relays may be able to help more. I'll keep thinkin though. I mean, a ignition switch, coil, distributer, control module, alt, starter is about all there is to the starting system and you have replaced half of that. The alt and starter shouldnt have anything to do with the problem your haveing. I bet there is a relay or sensor somewhere in there thats not letting power to the coil.
