Wrenching on my 1st jeep, a '93 YJ 2.5L 5 speed with vacuum shifted Dana 30 axle. The plan was to simply replace the axle seals & except for now replaceing the steering dampner, tie rod grease cups & front shocks it remains the same. The problem I've run into is the passenger side axle tube shows damage at the point just inboard of the shift housing where the axle tube has fixed splines that match the axle shaft. The damage is that a few of the splines show broken "faces", like just where they start at the very end of the tube. Can anyone tell me if that's the extent of the damage will it effect my front axle in a bad way? I'm not foolish enough to think it's good however maybe it's not terminal either? Any opinions? Thanks. MGD
