simple2029
Hello all i have a 6cyl 4.0liter i know the pcm is static timing and i cant change it but i got my jeep for my mom who is on dialices due to kidneys failing.
My obd2 said a lot of bla bla..
what i put in new.
Plugs wires ign coil distrib cap rotor and cam sensor.
Crank case sensor. i hallowed the cat since it was cloged.
I put in mas air flow thing and the little rubber hose was good.
There are on more codes.. the jeep idles ok
but has a random stall.
I was told to use the obd2 and see if the pcm was going bad and the ignition timing is 10.0 to 19.50 at idle
at 2000 rpm its 40 to 42.
Any in put please advise....
Is that timing do high or low. ?
i have no codes and the temp dont matter.
But $400 for another pcm is way a lot of money for m.
what i put in new.
