99 TJ Door Adjustment
Botz 13
Hey Everyone! You were all great with my last post about my Weber Carb. I thank you for that. I have moved on from my YJ to my TJ and with no surprise I have a water leak. Jeeps are great aren't they?
I was wondering if there is anyway to adjust the passenger door. There is a gap above the door with the rubber seal is. I had a puddle like you wouldn't believe on the back seat floor. Of course nuttin on the front cause I had the drain holes open. But I have deduced that it is definatley the gap around the door that is giving me this problem. Please help. Thanks for the time fellow Jeeperz!! :-) [addsig]
1059161
does it have full steal doors? and on the tj the drain hole has a plug if the plug is in the hole you might have a water leak somewear else . What i would do is sit in it and have some spay it with a hose that will tell you where the leak is [addsig]
