A/C cont.
bigjeep
its a 94 jeep cherokee and every time i use the A/C after about 10 minutes it starts to make a loud deep toned sound i think it is coming from the dashboard you can problaly hear it from outside the jeep too.
_________________
1073529
Will it also make the sound with just the vent on? If so, the blower motor might be going out. If it only happens with the A/C on, check (or have a shop check) the system pressures. Be warned the A/C system high side is under HIGH pressure, use caution.
Good luck
-Nick[addsig]
