A little help please.
monsterrd
The other day, in the snow my 4wd stopped working. took a look underneath and my 2 vaccum? lines came off from the t -case.My question is, Does it make a difference which one goes where, two connectors on axle? Appreciate your help. Thanks 89 yj :-( :-( :-x :-x Is there a designated right and left line?
edited by: monsterrd, Feb 27, 2003 - 02:01 AM[addsig]
1057072
The 4-way vacuum connector on the transfer case will only go on one way.
The two vacuum lines on the front axle have to go on a certain way, and the 2-way vacuum connector will only go on one way on most jeeps. If the 4wd light comes on in 2wd, it's reversed.[addsig]
1057084
Thanks a lot , I'll fix it thurs. before work, again thank you. :-) :-) :evil: :evil: hopefully I get it fixed before the next snow, so I can play.
edited by: monsterrd, Feb 27, 2003 - 04:10 AM[addsig]
