I recently replaced my seized up AC Compressor, drier, and orifice in my 98 Sahara.  Pulled a vacuum, verified no leaks, and put as much r134 in as possible without the compressor engaging. I used a 14 gauge wire to jump the low pressure and high pressure sides with no luck.  When I jumped it directly from the compressor to the positive battery terminal it engaged immediately.  I swapped AC relay with one I know to be working.  Any suggestions what could be my issue.  The slider works for fan, heat, etc. but I cannot get the compressor to kick on.  Thanks.
