B brandon217 New member Mar 18, 2012 #1 Bought a 97 jeep wrangler rear end was completely out of it, put it back in and had to put brakes on it and now smelling burnt smell after I drive it
TerryMason Administrator Staff member Mar 19, 2012 #2 Welcome to Jeepz.com Drum or disc brakes? After you drive around is one of the wheels really hot to the touch?
B brandon217 New member Mar 20, 2012 #3 They're drum brakes, not that I could tell, I did a circle around my court a sack and back in the garage and I could smell it
RudeDog New member Mar 20, 2012 #4 If you just installed it (rear end) and it hadn't been run, it could be odd smelling /breaking in. Jack up rear end, spin tires, same amount of drag left to right? One stops faster than the other, that usually means that side is dragging, adjust it.
