Advice on motor swap??
Rasp
hiyas, ill try to keep this short hehe heres what i have 87 wrangler 4.2 peugot 5 speed [ack all garbage i know alrdy] heres what i have to put in 350 tpi and th 700 auto transmission all out of a 86 Z28 camaro the motor part dosnt worry me i know what needs to be done there what i need help on is the transmission, can i use the 700 2 wheel drive transmission with my transfer case?i know if i can ill need an adapter i just dont know if the 2 wheel drive transmission can be used or do i need a 4wd unit i dont do any severe offroading with my jeep, i just already have this motor n transmission, got a really good deal on them paid 200 buxx for the entire car motor trans computer everything there i just wanna make my jeep reliable and get it to pass emissions somthing the old 258 dosnt seem to be capable of
any help or hints or advice greatly appreciated![addsig]
1046719
the transmission will work, goto www.advancedadapters.com for more information they're a lot of help in these conversions the 700r4 is actually a fairly good transmission to do the swap with for on-road performance[addsig]
1046723
Just an opinion, other than the low first gear, the 700 R is junk. I´ve replaced a dozen of them. I´ve still got the original TH 350 running in my 81 1 ton. The 86 has a few improvements, but the best improvement they ever made was discontinuing the model. After 93 they built (for a few years) an overdrive transmission (non-computer controlled) that has a good name. The all time winner is the TH400 (bullet proof).[addsig]
1046751
if i was to go with an auto transmission the 700r would be the one.... yes it is not as stout as a th400 but it is also going in a jeep and you are no way near as heavy as a 1 ton truck. not saying that mudderchuck is wrong, the early 700r's did fail a lot....but with a low first gear, and an overdrive this transmission has found it s way in many serious rock crawling jeeps..since you got the motor and trans so cheap. the most expensive thing will be your adapter..good luck and with all that power be nice to your axles.....
you know you could just switch tcases and axles to match all you chevy parts already..
