Air intake... Can I just put a cone filter on?
Jeep#3
Let's say I removed my stock air box and added a cone filter to fit the end of my stock air intake hose, would this give me the same results as buying an expensive intake system? Any comments? Suggestions?
Thanks!!! [addsig]
1062457
doesn't sound like it wouldn't work. when it came to air filters...the thugs in my town that hang around 7-11 rigged up some interesting things. i see no reason for it not working. just might not work as well..but who knows[addsig]
1062479
Do I need to extend my existing hose to have the filter closer to the origianl air-box location? Or would it be OK a bit closer to the engine?
Thanks again!
edited by: Jeep#3, Mar 30, 2003 - 03:23 PM[addsig]
1062484
it would be better if it was in the stock location, because there is a fresh source of air coming in at that point through the airbox intake tube. But it won't be enough of a difference to worry about. Basically, don't point the tube toward the engine, and you'll get much better results than the stock airbox[addsig]
1062485
One more question about this situation... What about getting an air filter to fit directly on top of the throttle body? Any problems with this? Maybe too much warm air? I am really interested in this topic because I do not see spending so much money on an air tube when ther might be other alternatives.
Thanks again and again! :-) [addsig]
1062487
yeah.. i think that would work.. but then you will be pulling in from right on the engine, and i think the end of the cone would be quite close to the hood, not getting much space to pull air from there... if you get a piece of pipe, and connect your stock tube to the filter, that would work quite well[addsig]
1062492
I know! I know! I said that would be the last question before! Oh well. Anyways... What size filter would be recommended to be put on the end of the hose? What brand? I see K&N has the 6x9 and Powerstack has 5,6,7,8" and up. Which would be better? Thanks again![addsig]
1062507
The larger, the better, as long as it fits without being in the way too much. I've seen them bolted directly on the TB, but when idling/crawling, very warm air rises from the exhaust manifold. Better to pull from the other side of the engine.[addsig]
