steady.foot
88 YJ. No lift. Does anybody know what fits? Can't find any anywhere. Not going to lift it with shocks. Just want a little boost once in a while. Don't want booster springs or add a leafs.
another option to look into if interested, there is a shock that replaces your stock shock and has a variable rate coil spring around the body that acts like a over load spring. A friend uses them on his pick up, They work well and will not effect ride quality with in the normal range of suspension movement.
edit, found them
Gabriel HEAVY-DUTY SHOCKS WITH OVERLOAD SPRINGS - JCWhitney
