Baseline 4x4
The Alloy USA® Hub Conversion Kit is designed to upgrade and replace the non-serviceable wheel hubs found on 1984-06 Wrangler and Cherokees. Now you can lock and unlock your front hubs to reduce driveline strain and improve fuel economy! The Deluxe Hub Conversion kit includes a set of Rugged Ridge® Manual Locking Hubs, high tensile strength 27 spline inner and outer Alloy USA® 4340 Chromoly Axle Shafts, 1/2 ton capacity aluminum internal mounting hubs, Alloy USA® X-Joints, machined front brake rotors, bearings, seals and hardware.... everything you need to upgrade your rig and prepare it for the trail. Maximum recommended tire size is 33â€.
Alloy USA Grande Hub Conversion Kits Feature:
• Better fuel economy by freewheeling in 2WD mode. Decreases tire wear since unlocked manual hubs rotate more freely.
• Alloy USA® 4340 Chromoly Axle shafts that are 40% stranger than stock axle shafts.
• Includes beefy Corrosion resistant die cast aluminum Rugged Ridge® Manual Locking Hubs.
• Replaces stock U-joints with premium Alloy USA® X-Joints
• Includes 1/2 ton capacity aluminum mounting hubs and hardware.
• Decreases wear on internal components by engaging front axles only when needed.
• Unlike other kits, we include pre-machined brake rotors to eliminate guess work and hassles.
• More durable and cost effective than replacing or servicing factory hubs and axles.
• Great for any “tow vehicleâ€.
12198 - ALLOY USA DANA 30 MANUAL LOCKING HUB COMPLETE CONVERSION KIT, INCLUDES ALLOY USA INNER AXLE SHAFTS, JEEP WRANGLER (YJ) 87-95 ELIMINATES DISCONECTS, (TJ) 97-06, CHEROKEE (XJ) 92-01
12194 - ALLOY USA DANA 30 MANUAL LOCKING HUB CONVERSION KIT, JEEP WRANGLER (YJ) 87-95, CHEROKEE (XJ) 84-91
12195 - ALLOY USA DANA 30 MANUAL LOCKING HUB CONVERSION KIT, JEEP WRANGLER (TJ) 97-06, CHEROKEE (XJ) 92-01
Free Shipping on all orders over $199!
Tony Feichter
Jeep Parts and Accessories
Baseline 4x4 Outfitters
1-866-554-5946 Toll Free!
260-636-7565
www.baseline4x4.com Jeep Parts and Accessories
TonyFeichter@baseline4x4.com
