69jeepcj
I am having problems breaking my alternator bracket in half. The motor is a 65 chevy 327, double hump heads with no acessory holes, roughly 350hp and around 412ft tq, every time I floor the pedel and run through the gears from 2nd to 4th hard it snaps the alternator bracket in half. I have welded or replaced the bracket several times and would like to get this fixed. I have a Mr. Gasket bracket with the long arm that go,s from the water pump to the drivers high side of the motor, then another bracket under the alternator that is attached to the motor with the header bolts. The header bolt bracket is the one I keep breaking in half. I have looked at the pulleys and they all line up, I have watched the pulleys with the motor running and they look fine. My thought is that when I mash the pedel, the torque is pulling on the adjuster bracket coming from the water pump and snaping the lower bracket. I have thought of making a lower support arm/brace to maybe help keep it in place, but not sure this will help. What do you guys and gals think? Thanks
