1055787
Well i did it. it tok some time but i flipped my jeep! damn snow covered roads! well it put my jeep in the garage long enough to get caught up on a few problems i have. oil leak waz fix a few things here a few things there but i decided to redue my rear brakes the driver side went great no problems but then the passenger side came and as i took the drum off grease was everywhere i know it's not brake fluid because i just replaced the wheel cylinder so i figured it waz either an inner or outter seal. so after some hammering i got the nut off the far end of the axle but i can't seem to get the axle out i need to replace the seals somewhere in the axle but i'm at a stand still right now any help would make this project just that much eaiser. i have a CJ-7 with no lift and 31 tiresthanks for any help you can give[addsig]
