another control arm question????
tj-angler
i was looking at the ribicon express control arms and i noticed that the upper control arms are attached to the lower control arms and since i an building my control arms i was wondering if i should build my upper arms attached to my lower arms and if i do what will i get out of building them this way ? :-? [addsig]
1062033
That would most likely be for a long-arm kit, which would require you to fab lower control arm mounts. Sounds like you are much better off buying a kit, considering the questions you have asked. I mean no disrespect, but usually if you have to ask those questions, you are in over your head. Fabbing coil spring suspensions is tough and takes a lot of experience. I hope it works out for you and don't let this advice turn you away.[addsig]
