Allen's Offroad
Get a free ARB 804100 Annex Tent ($267.00 Value) through July 31, 2017 with purchase. The ARB annex is the perfect way to add a little additional living space to your roof top tent. This additional zip on room will fit a couple of extra cots if you'd like to have the kids sleep downstairs or it also provides a terrific dressing room or concealed location to keep your waterless toilet.
$1450.00 shipped for limited time. CA residents there will be sales tax of 7.25%. Click above image to order!
ARB Rooftop Tents integrate an updated design with new materials for better strength, rigidity and water resistance. Manufactured from high quality fire retardant poly/cotton fabric and incorporating an Oxford polyester flysheet, rooftop tents are easily mounted to ARB's purpose designed roof rack, or suitably load-rated cross bars. A retractable aluminum ladder makes getting into bed a trouble free event.
Super strong 1" anodized aluminum poles improves strength and provide corrosion resistance properties, while a high density 2.5" foam mattress (with removable cover) ensures you'll sleep soundly. And don't worry about mosquitos, ARB Rooftop Tents feature insect screened windows and doors.
SIMPSON III ROOFTOP TENT
The ARB Simpson III rooftop tent delivers the ultimate in ease and convenience when traveling. Unfolding in minutes, a rooftop tent provides sleeping quarters off the ground, protected from the elements and wildlife. All bedding can remain inside the tent during the journey, freeing up vital storage space in the vehicle and allowing the tent to be quickly and easily packed away. Also aiding the fast pack down and setup, a unique bungee cord system keeps walls tucked in to assist in speeding up the pack down to get you back on the road faster.
FEATURES:
Series III tent incorporates an updated design and new materials for better strength, improved weight limits, UV rigidity and complete water proofing while adhering to CPAI-84 fire specifications, a requirement for the United States and Canada.
Manufactured from high quality, waterproof, poly/cotton rip stop canvas - 300GSM PU impregnated canvas
Incorprates oxford polyester flysheet with excellent water shedding ability - 1000mm/3ft water head
Taped sealed seams for double protection & all weather vents for reduced condensation
1" diameter anodized aluminum retractable ladder support up to 265lbs
2.5" high density bonded chip foam mattress with removable cover for increased comfort and durability. Bonded chip foam evenly spreads weight from the body better across the mattress
Incorporates unique twist lock pull out all weather awning and true optional zip-on annex
Fine insect screened windows and door protecting from the smallest insects for better night sleep
UV stabilized laminated welded PVC cover with high quality vision zippers. Triple strap design.
Quick pack bungee cord system to assist when packing down tent, speeding up pack up time.
Easily mounted to ARB's purpose designed roof racks or most rated cross bar systems.
Unique configuration to unfold off either the side or off the rear of the vehicle.
All weather entry door with grab straps to help assist getting into the tent.
Fully backed by a 2-year warranty
Size:
55" (1400mm) wide x 94.50" (2400mm) long x 51" (1300mm) high
All Aluminum Components Feature an Anodized Finish for Improved Corrosion Resistance and Appearance
Total weight 154lbs/70kg
Comes Complete with Mounting Hardware, Wrenches, Ladder, Travel Cover and Comprehensive Instructions
ARB Awnings can Also be Paired with the Rooftop Tent.
Fitting Details:
This part number will fit the following makes/models: The ARB Rooftop Tent can be mounted to an ARB touring style rack or any flat roof bar system with 95lb kinetic load rating.
