G gonzo891 New member Jul 20, 2003 #1 1056273 i removed my axle and i'm now wondering how i should get the hub off the end. i know i could go to a shop and pay to have it done but i was wondering if there is a back yard/garage way that might save me some time and money.[addsig]
Bounty__Hunter Super Moderator Jul 20, 2003 #2 1056291 36mm socket and impact wrench to remove the axle nut, then slide the bearing assembly off.[addsig]
joeycj5 New member Jul 20, 2003 #3 1056379 Once you have the nut off, use a 2 or 3 jaw puller to get the hub off. $25.00 at Autozone.[addsig]
Bounty__Hunter Super Moderator Jul 20, 2003 #4 1056407 He's already removed the axle, so the puller won't work. Just has to remove the axle nut and the bearing assembly slides off the shaft. The puller would work if the axle was still installed in the housing.[addsig]
