1059496
The best possible way is to find the wire in the fron of the vehicle and in the rear, use a multi-meter snd test for continuity. (the meter should beep) if it doesn't, you have a cut wire. if it does, test the continuity between the wire and the body of the jeep (any good ground) if that beeps, then you have a wire that is most likely exposed and is "grounding out" and most likly either blew out a fuse or if it is an older vehicle, it might be a fusable link. If the meter still does no beep, you might want to check the switch at the transmission.[addsig]
