1049443
I know that the bolt pattern for an 89 YJ is 5 lugs at 4.5" apart. I believe that the standard backspacing is 4, but I'm not sure. What does it exactly mean? Does a higher number move the wheel out of the wheel well or vice versa? I'm looking to lift it this spring and get some 15x8s with 32"s. I had 31"s about a year ago and when I turned the wheel all the way to the left or right, the tire would rub the spring. Not good at 30mph.
Little info is much appreciated.
