Is it water? I thought they used some type of oil. It is also surrounded be a piece of plastic or wood that is flat on both sides.
In my HO I think it would be easier to remove the entire seat so you can have a clean look at the underside to determine what you need to do to repair/replace the LEVER.
YOU DARE QUESTION ME! HUH, but your probably correct,water would freeze in cold temps. It would help if ya could post a picture of your lev er situation, so maybe some one could come up with an idea on how to help you.
These vials, common on most ordinary levels today, feature a slightly curved glass tube which is incompletely filled with a liquid, usually a colored spirit or alcohol, leaving a bubble in the tube. At slight inclinations the bubble will travel away from the center position, which is usually marked in some manner. Alcohols such as ethanol are often used rather than water for a variety of reasons. Alcohols generally have very low viscosity and surface tension, which allows the bubble to travel the tube quickly and settle accurately with minimal interference with the glass surface. Alcohols also have a much wider liquid temperature range, and won't break the vial as water could due to ice expansion. A colorant such as fluorescein, typically yellow or green, may be added to increase the visibility of the bubble.
