Baseline 4x4
We are having a blowout sale on ring and pinion sets for the 07-12 Jeep JK Wranglers. Let us know if you have a Rubicon (D44/D44) or Standard (D30/D44) and the ratio or ratios you want a quote on.
We have several different brands of kits as well as kits with master overhaul kits and mini overhaul kits. We sell Yukon Gear, USA Standard, Alloy USA
Front and Rear pair of Ring and Pinions are available for less than $299.00 on both Rubicon and Standard JK axles. Contact us for a quote and get your JK some extra power.
When you change your tire size you need to make sure you have the right gearing to get optimal fuel economy and power. A good way to calculate this is to mutiply .12 by your Jeeps tire diameter (Example: .12 X 38" = 4.56). Here at Omix we have a made an easy to read chart for you to get a good estimation on the best gearing for your Jeep. The three distinct colors below can help you decide what is the right gearing for you...
Green = Best MPG, this is what you would want to get for the best fuel economy and highway cruising.
Brown = Best Overall, this is good mix of power/MPG and considered best for daily driving.
Orange = Best Power, this will give you the best performance for towing power, but at the cost MPG.
These calculations are assuming a manual transmission at 65 MPH with a gear ratio of 1:1. If you drive an automatic your RPMs will be slightly higher,and if you have overdrive your RPMs will be slightly lower.
Contact us for other Jeep Applications.
