Postofficemike
Do I need to replace the brake booster if, when I press the brake pedal, it goes almost to the floor, but if I pump it 3 or 4 times it builds up? Not good for a quick stop if someone pulls out in front of me.
No. That is what is confusing. There is no drop in fluid level. No wet spots around any of the bleeder valves. No leaks from fittings. What I noticed today is that if I pump the brakes I can hear an air sound from under the brake pedal area. Do you think some part of the booster is leaking from the back? Thanks.My suggestion would be to park on some clean concrete and pump your brakes for a while, then crawl under your Jeep and look at each wheel's brakes for fluid. You may need to come back the next morning and look again.
Do you need to add fluid in your master cylinder periodically?
