Bump Stops?
Tug-n-pull
I have looked at all kinds of after market and factory bump stops for where the frame to axel meets on a bottom out hit! Mine are shot! Does anyone have any preference to what is good for this spot? As mine are shot! Has anyone come up with a good home remedy for this item? Thanks for you responce in advance. Tug[addsig]
1050329
WHAT ARE BUMP STOPS
IF I PUT THEY ON WILL THE BUMPS GO AWAY
J/K TUG
1050350
Nope the bumps will always be there that is life. They are the rubber stops that take the blunt of the shock and force out of the axels hitting the frame when you bottom out! 1bigmf would not know about this as his Jeep is so high he would have to drop it off of a cliff of considerable heigth to ever bottom out!
I on the other hand am a simple jeeper and I hit things to hard sometimes and my bump stops are worn out from use! so I need to replace them. Thanks RAVEN13 I looked a Daystar and most likely will go that route. Was just wondering if ther was a preference out there. Tug[addsig]
