Cheap selectable front locker for YJ's
Bounty__Hunter
Super Moderator
1044131
I had a friend of mine weld my front differential (Lincoln Locker
). I then installed a vacuum switch from a SJ with Quadratrac 4wd. I spliced this switch into the factory vacuum harness for the front axle disconnect. I can now disonnect the pass. side front axle at the flip of a switch. I have true 4wd and can switch to 3wd to make tight turns easier on the trail. I've used it for a while now, works sweet
