89cherokee
So the brake pedal on my '89 cherokee goes close to the floor before stopping the jeep. So I read the forums and I replace the master cylinder. I go to bleed the brakes. I notice the bleed valve has been sheered off, so I replace the caliper. New master cylinder, new caliper, new fluid. I bleed the system...and now I have no pedal pressure. I read the forums and I decide to replace the brake booster...re-bleed the system and no pedal at all. Step on brake pedal and its to the floor. Did I miss something? How important is the bench bleeding of the master cyclinder? I figured I would take care of that as I bled the system? Any suggestions will be appreciated. Thanks.
