1043159
I'm trying to understand a drive-train problem my very elderly father is having with a 1993 (Grand?) Cherokee.
Unfortunately he lives alone on the other side of the continent from me and has never let me drive his Jeep, so I don't have a lot of first-hand experience with it.
He is also not the most reliable witness to events, given his age.
He says he was backing out of a parking space, when his Jeep came to a sudden halt with a loud noise and the automatic transmission shifter would no longer move. He also says that the plastic bag he had sitting on the transfer case lever -- don't ask me why -- blew off at that time.
Eventually he messed with the transfer case lever and the automatic transmission lever and was able to drive home -- a few blocks away.
It is quite possible that he had been driving in four-wheel drive when the problem occurred. He is not really on top what what is going on with his Jeep.
My questions are these:
1. How do you put this jeep into 2-wheel drive?
2. Are there a Hi and a Lo range of 4-wheel drive?
3. What could have caused the problem in the parking lot?
4. When the transfer case lever is in the middle position between forward and back, is that 2-wheel drive?
5. Should the lever be wiggling loosely in that position?
6. Does the transfer case lever move in a straight line, or do you have to push it sideways to move it back or forwards?
Thanks for your patience with a newbie and any help you can provide.[addsig]
