well, im back again with another problem.You all helped me out the last time,and once again im stumped!
I have an 89 jeep cherokee limited 4x4..4.0 motor,automatic.
i have been having a problem with the jeep dieing while driving down the road,or even at idle.....it also would act up alot worse when i turned on the a/c(that is what throws me).well, it finally died on me and wont restart,had to have it towed home.the coil and module are fine,i changed them out with a known spare set i had anyway.its getting fuel,but no spark!
i replaced the cps 2 times and still nothing..i checked it with an ohm meter,and it checked out fine.all the tune up parts are new...the only thing i havent replaced is the camshaft position sensor!!could this be my problem? is ther any way to check this part?and if so,what should i do to check it?
any help would be grreat,im at a loss...thank you..
matt h..............central florida
