Greetings:
My Jeep is a 1989 Cherokee (pioneer) with 152K on it. The engine leaks oil and oil does accumulates in the air filter. A rebuild is on the horizon, but until then....sometimes it just will not start. Turn the key, engine turns over rapidly, but no luck. I can hear the pump come on before turning the key all the way to start. Often if I wait a few minutes to an hour or so it will then fire right up. WHen it does start, it is usually within the first 3 seconds of trying.
Suggestions? I noticed some posts about the Hall effect sensor. Is this a possibility? Also, I recently bought a jar of the Techron fuel injector and added it to the gas (is it snake oil?).
Any suggestions or comments would be greatly appreciated. It looks finances will force me to do all the work, so I need to educate myself as much as possible. THanks for any advice.
Sean
Sean
