CJ mechanic in Raleigh
mechetti
Can anyone recommend a good CJ mechanic in Cary (the Raleigh area)?
I have a 1980 CJ7 with an AMC 360 in it. I just moved here and I am having issues with my timing, which keeps getting knocked off. I had a mechanic reset a couple of times before i moved and it is off again. It usually runs good for about a month, the starts running really rough. The distributer is tight, so not really sure what is going on. I don't have the equipment to reset the timing myself and I can't keep paying to fix it.
Any ideas on the possible issue and how or who I can take it to fix it?
Timing chain and gears are probably worn out.
Good call. Distributer was loose the first time around. Might be it. I will check.
