jay79cj7
RE: Re: RE: What is the difference
I just put a painless kit in my 79 CJ-7 and haven't got my tach working yet. The kit has a tach wire that goes to the negative side of the coil and leads back under the dash to hook to the tach.
I think the tach I have is original, and if not, it is a replacement because it looks factory. Besides the wires for the lightbulb, there are 2 heavy gauge (like 8 or 10) red wires coming off the back of the tach. I figured one must be hot, the other must be for that tach wire on the new harness, since that's how all the other gauges work. I was wrong, connecting it that way kills the engine.
I looked at the way the old harness was connected, and one of the tach wires comes straight off the ignition connector, and the other goes to the fuse block which leads through to the main 12V wire coming from the battery terminal of the starter solenoid.
So, it looks to me that the tach is hooked in series with everything on that main circuit. Does this make sense? Is this right? I do remember noticing that wire was pretty warm when I was under there one time!
Can someone with a CJ check to see if this is how theirs is wired? I want to be sure before I start hacking into my new harness.
Thanks!
Thanks!
