principalb
Greetings everyone, I need some help, I bought a 75 cj5 with a straght 6 258 Ci motor. The battery has died - often even after just driving the vehicle and parking it. Go to turn it over and it is dead. I have replaced the battery, the coil, the ignition coil, the alternator, and have even placed a power kill switch on the negative side of the terminal on the battery. Yet the battery dies within about 30 minutes after driving it and this by the way is intermittent happens often then not lets say the car sits for a few days all of a sudden its fine, then drive it then go abck to drive it 40 minutes later and voila dead. . I literally watched the radio shut down in about 40 minutes while washing the car. My mechanic ran a voltage meter on everything and cannot find a drain. My thoughts are that maybe it is in the ignition switch perhaps bad battery cables? I did notice that the battery was hot even after the kill switch on the negative side was applied whihch means to me something is pulling the juice and pulling it quickly. The starter motor is not running by the way. so I think that was eliminated. But what can drain the battery so quickly. Any thoughts?
